Can I use the AC DElCO rapid fire 5 plug on my 87 corvette aluminum heads?
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
Are the se the right plugs for the job? Please point me in the right direction as i just put these heads on my new motor and have no idea what plug to run on them and definately do not want to do any damage.
thanks.
thanks.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Go to a parts store and look up what the stock plugs are for an '87 Corvette. If nothing else, you'll have a plug to start from that way.
Engine: 383 Stroker
The problem is that I have gone to 3 different parts stores and look tgroughout the net and some say use the Ac Rapid Fire 1's while others say use the Rapid fire 5's. The casting # on the head is #1000832113. So which are the right plugs???
anyone?
anyone?
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
According to AC Delco's online parts catalog, the '87 Corvette takes the Rapid Fire #5's. These are a gasketed plug, which the aluminum Vette heads of this vintage uses.
Car: check
Engine: check
Transmission: check
The proper plug for the '113 head has a 3/4" reach, a gasketed seat, and the 5/8" hex. The Autolite #3926 plug is correct. Can check a cross reference and/or physical form in order to get the correct Rapidfire.
RBob.
RBob.
evilstuie
Feb 28, 2016 03:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
