Let's play, "What did I break?"
Old May 20, 2001 | 12:50 PM
MR. JORDAN's Avatar
While passing a car yesterday, i pushed my little 305 real hard. Ever since then, I have this really bad deiseling problem every time i punch it? I still have a lot of power,she idles really nice,and holds a solid RPM.What did I break to cause a knock when putting her down?
Thanks in advance!!!!!!!!
Old May 20, 2001 | 01:08 PM
SUPER-SPORT-CHEVY's Avatar
What probably happend is a conaminate passed through the fuel filter and got stuck in the carb or an injector. Most likely it will pass through and the problem will go away. You should change your fuel filter and ad an cleaner additive to your fuel to speed up the cleaning process. 44k works excellent but a cheaper additive will probably work well also.
SSC
Old May 20, 2001 | 01:16 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
you could have broken a piece of carbon loose also, that can make the engine do strange things.
Old May 21, 2001 | 01:50 PM
MR. JORDAN's Avatar
Yup! I just had bad gas. Thats all!
Old May 21, 2001 | 03:18 PM
Bort62's Avatar
I bet those close to you are Glad that episode is over...
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
antman89iroc
36
Jan 31, 2016 08:42 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
rusty vango
Sep 29, 2015 02:44 PM
Bob88GTA
Sep 10, 2015 09:07 PM
