need 416 (head) gurus in here now!
Old Oct 13, 2004 | 05:14 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
http://www.fullsizechevy.com/forum/s...d.php?t=127976
Old Oct 13, 2004 | 05:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have to "log in" to see whatever's in that link.
So, what's the issue?
Old Oct 13, 2004 | 06:37 PM
five7kid's Avatar
Okay, after getting in to look at that other board's thread:
To each his own. I've argued 'til blue in the face that World S/R Torquers are a better starting point for a 305 than factory 305 heads. I wouldn't consider them bolt-ons, though (even the magazines pocket ported them b/4 "comparing" them to stock factory 305 heads). With DIY porting and 1.94/1.50 valves, either will rival out-of-the-box Vortec flow (of course, there's more to Vortecs than flow). And, there's more to the Worlds than thicker castings vs. 416's - the chamber shape is different, for instance.
Vortecs are attractive, but people need to understand their (argueably severe) out-of-the-box limitations, since a lot of the cams people want to run have too much lift for them w/o modification; and just as important, they may not be the best choice in emissions-required applications. I just don't understand why the factory continues to cheap out with press-in studs, or why outfits like SDPC don't include screw-in studs with their "upgraded" Vortec heads.
Aluminum L98 heads? Hardly an improvement over 416's on a 305 w/o significant work. But, they can be nice when properly worked over.
I wouldn't go out and look for 416's if I was building a 350. But, if I already had worked-over 416's (or World 305's - wink, wink) and was building a 350 shortblock, I'd certainly consider using them on a mild street performance build-up.
In the end, the amount of money you spend is almost always more when you buy new heads than it is when you improve what you've got. The HP/$'s is typically pretty close, but the max raw HP # will always require a higher $ number.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
