Let's see how good you guys really are...answer this!!
Subscribe
May 20, 2001 | 12:02 PM
I finally started putting my engine together again now that I have a block without a hole through a cylinder wall into a water jacket. I have the rotating assembly in and I was going to put the roller cam locking plate on and it's different than the last one I had. It's the oval plate that has two torx bolts holding it over the end of the cam. My original block was a 2-bolt Camaro block , but now I have a four-bolt out of a truck. I don't know what year the block is, but I'm guessing I just need the specific plate for that block. It's a one-piece rear main seal. Are all the truck block plates the same or do I need to know the year? If I need the year how can I find it out??
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Reply 0
May 20, 2001 | 12:23 PM
Paul:
There are only two plates that I know of, early and late, the bolt pattern is wide on the early and narrow on the late.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Reply 0
May 21, 2001 | 12:55 PM
You have a one piece rear main so that tells you that you have a 87 or later and they should be the same,but I could stand corrected.
Reply 0
May 21, 2001 | 01:09 PM
Like Don said, there are 2 different ones.
The dealer can get either one, they are cheap.
Reply 0
May 21, 2001 | 05:40 PM
Hah!!! I called the dealer twice today and they didn't know anything about the narrower one!! I hope I'm not screwed. Does anyone know how to find the year from the castings on my block? Or does anyone know what vehicles had the narrower plate??
--RPM Racing--
Reply 0
Subscribe
