ASAP- 89 TTA Engine Fire- OK to Buy?
Old Oct 15, 2004 | 03:51 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I have an opportunity to buy a slightly modded 89 TTA that had an engine fire for $2,500 locally (MN).
It is a rust free (TX) car with new trans, tires, etc. Body is good, except hood is warped a bit...fire was small and located at rear of engine compartment...
I am going to look at the car tomorrow morning and need to make a bid on the spot as I am first in line for the bid.
How tough will it be to re-do the wiring harness? Can I buy one aftermarket or will I have to mod a V6 or TPI harness? How about the dash wiring if I need it? Is it available?
I need to know by tomorrow morning...any input would be appreciated!
TIA
Old Oct 15, 2004 | 05:57 PM
Engine: LS3
Transmission: 6L80E
I found some info that it uses the GN computer...but no info on the wiring harness.
Additional questions...
1. Does it use GN accessories on the front?
2. Is the dash just a regular TA dash with a special guage cluster?
3. Anything else special about sensors, wiring, etc?
Anyone know???????????
Old Oct 16, 2004 | 10:20 AM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
Transmission: GM 2004R
TTA's use a TTA specific engine harness, I think you can still get NOS ones at John's Performance.
They started life as standard 305 GTA's so I don't think any other wiring is different.
They use a different serpentine belt than a GN (about a half inch shorter) so I think the accessories might be different but its probably just due to the different cylinder heads making the accessories closer together.
The air conditioning lines, headers, overflow tank heat reflector, intercooler and intercooler shroud are also TTA specific.
Most everything else is either a regular TA or can be replaced with a GN part.
Good Luck!
Old Oct 16, 2004 | 11:39 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
every once in a while I run across tta eng wiring harnesses ( about 200.00-600.00) depending on who's selling it and the demand I would fix the one it has (as long as it still looks like a harness)
Old Oct 16, 2004 | 04:06 PM
Engine: LS3
Transmission: 6L80E
Thanks very much for the replies...
I just looked at the car and the fire breached the windshield and melted a chunk of the dash/wiring inside the car. The insurance company geniuses also didn't cover the windshield and we have gotten a lot of rain over the last few days...
I think the owner will be parting it out...but he isn't sure yet. Maybe I can get some rust free body parts!
Thanks guys!
Old Oct 16, 2004 | 04:55 PM
87TAWS6's Avatar
Car: 1979 Firebird Esprit Redbird, 1987 Trans Am WS6
Engine: 301ci, 305ci
Transmission: T/H350, 700R4
if he does part it out. pls PM me im definitly interested in the engine for a little project.
Old Oct 17, 2004 | 06:52 AM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
Screw parting it out I'd fix it.
Jake_92RS
Jan 28, 2020 10:37 PM
italiano67
Dec 11, 2016 09:21 AM
lee01
Apr 9, 2016 01:56 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
