Anyone runnig gear drives instead of timing chain ?
Old Oct 15, 2004 | 05:48 PM
wilson1070's Avatar
Car: 1985 Trans Am
Engine: 4 bolt main Chevy 350/330hp
Hello all, thinking about putting in a Pete Jackson gear drive...The noisy" model .
Anyone running gear drives ? are they really that noisier ? Are they noisier then the intake noise on a carbed engine?
Old Oct 16, 2004 | 01:17 AM
JesasaurusRex's Avatar
Im running a quiet gear drive (dont make a noisey one for roller cams) and I can still hear the whine a lil. My car is pretty loud as it is so i can only imagine how loud the noisey one will be. Best I can do to answer that question.
Old Oct 16, 2004 | 01:40 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I've heard them. Some are so loud its just stupid, but some aren't too bad.
IMO, a good double-roller chain is still the way to go on anything streetable.
Old Oct 16, 2004 | 07:18 AM
red87iroc's Avatar
Car: No F-Body Currently :(
Engine: none
Transmission: none
Axle/Gears: still...none...(ugh)
Loud one sounds like a blower...
My neightbor has the loud one on his ******. Before I ever saw underneath the hood, I had assumed he was running a blower, the whine is so loud. So if you want people to think you are running a big old blower, get one!
Old Oct 16, 2004 | 01:09 PM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
If you have a stock computer-controlled engine, won't the knock sensor react to the gear drive whine and retard your timing?
Old Oct 16, 2004 | 01:24 PM
wilson1070's Avatar
Car: 1985 Trans Am
KnightWarrior---
I too have heard that is likely to happen.
That was a problem years ago with the later Iron Duke 2.5 fuelie
One of the timing gears were nylon, and when they wore out, ppl replaced them with steel. Then it was steel on steel, and the knock sensor went wacky.
Old Oct 16, 2004 | 01:37 PM
Air_Adam's Avatar
It might, it might not. Knock sensors are tuned to hear a specific frequency, so it might "hear" the gears, it might not.
I still think you should just get a double-roller chain. Its cheaper, works just as well (if not better) and its quieter.
Old Oct 16, 2004 | 03:30 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The loud gear drives can be very loud and annoy the crap out of you. If you like a constant whine that sound like a blower but with no forced induction benefits go for it. If you just want a unit that won’t stretch out like a chain and has a little noise then get a quiet drive. The quiet drive sounds like a stock 300 I 6 unit at low RPM then engine noise tends to drown it out.
Old Oct 16, 2004 | 05:37 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Even if you do like the whine that the gear drives produce at speed, the rattle noise (caused by clearance between the gears) at idle makes the engine sound like it's ready to fall apart. A lot of people I know have taken them off because of this.
Old Oct 17, 2004 | 12:12 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Really my 78 F150 with the I6 300 make absolutely no noise what so ever. You would never know that it was gear drive, if you didn't know.
Old Oct 17, 2004 | 01:18 AM
Air_Adam's Avatar
My cousin's Ford flathead (239ci) is gear driven too IIRC, and its pretty damn loud.
If you are standing in front of it with the hood open and at idle, it drowns everything else out. Even with the air cleaner off... and that tiny carb makes a hell of an intake noise too. Much louder than my Holley.
Old Oct 17, 2004 | 11:45 AM
bigbird88's Avatar
Some gear drives will send a vibration through the valvetrain causing premature wear on these parts. I did a search on gear drives on the net when building my engine and read a lot of negative articals on them. But they do sound good!!
Old Oct 17, 2004 | 12:29 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
My old 83 Bronco had alot of gear whine especially in granny and second gear. Could have been normal but it might have had somthing to do with the 300k on the set. I miss that fNord.
The PJ gear drive I have in the Malibu (BB 427) doesent sound like its vibrating but its not a sound that would suite the bird IMO.
Old Oct 17, 2004 | 01:47 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
HERE Is an interesting article.....
Old Oct 17, 2004 | 02:26 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
As someone said earlier, a gear drive sounds like you have a blower when you really don't. It's like the guy who takes steriods to look "big and tough" yet can't fight his way out of a wet paper bag.
If you liked to get picked on and lose a lot, go for it.
Old Oct 17, 2004 | 03:49 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Hmmmm, I got a gear drive and don't get picked on
Old Oct 17, 2004 | 04:28 PM
Car: Death Mobile
Engine: 666 c.i.
If you got the muscle to back it up, then you don't mind a good scrap. But if you have basically a stock or mild engine, I wouldn't want to be bringing attention to myself.
It's almost as bad as some of those ricers with a basically stock Honda who's only mod consists of a big fart pipe out the rear.
Old Oct 17, 2004 | 05:22 PM
flrtin1's Avatar
Engine: S/B
ok ok lol,
To clear a couple of things up that were mentioned above.
First wear, I have had a gear drive for over 50k miles with no problems or abnormal wear.
Second you can make a "loud" drive quieter or louder depending on how you install it
Third anybody who knows the diff. can tell if its a gear drive or blower, the gear drive noise is just that...... while true blower whine is made from the air getting trapped between the belt cogs and the drive pulleys
Old Oct 17, 2004 | 05:28 PM
flrtin1's Avatar
Engine: S/B
oh ya , by the way I guess this is why I don't get pick on for those who didn't get it :
Old Oct 17, 2004 | 07:32 PM
Car: Death Mobile
Engine: 666 c.i.
You forgot:
4th) They can see the blower sticking out of the hood.
Old Oct 17, 2004 | 11:03 PM
That blown engine in your Camaro is amazing! Road Warrior all the way!! What kind of gas milage do you get with that thing? Any detonation problems or overheating? Damn, I wish I could do that to my Z.
Old Oct 18, 2004 | 03:32 PM
flrtin1's Avatar
Engine: S/B
Thanks, it gets 22mpg highway, in town depends on how I am driving I am running 93 octane with 9lbs boost 7.5:1 static cr with no problems and with the griffin if anything it runs to cool.
This car has had a blower on it since 86
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
MY87LT
Aug 17, 2015 08:43 AM
