Speedo ration adapter
Old Oct 16, 2004 | 08:12 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I just changed the gears from 2.73's to 3.42's and bought one of these ratio adapters to get the speedo corrected.
Anybody have a pic of where the speedo cable comes into the transmission. I couldn't see anything real good.
Old Oct 16, 2004 | 10:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I may be wrong here but I do believe that your speedometer is electronic and not cable driven. Did you change out the speedo drive gear and the speedo driven gear in the transmission when you swapped gears?
Old Oct 16, 2004 | 11:43 PM
azvolfan's Avatar
I did not change out the speedo gear. Guess that is my next project.
Old Oct 17, 2004 | 12:24 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Just get the right drive & driven gears (driven has no shaft to it on your car) for a 3.42 or 3.45 rear A4 f-body. That adapter isn't gonna do anything for you since yours has a mechanically gear driven VSS. Your drive will be 15 or 17 tooth. IIRC, 15 is grey, 17 is red. If it needs changed, it's effort. If it's just the driven, it's cake.
-Matthew
Old Oct 17, 2004 | 01:46 AM
azvolfan's Avatar
WOW! Great moments in timing.
Just got my Chevy High Performance Magazine in the mail and it has an article about a thirdgen camaro that just went from 2.73's to 3.42's. They say it takes a grey 15 tooth drive gear and a yellow 41 tooth driven gear.
That explains it so even I can under stand it.
Old Oct 17, 2004 | 02:38 AM
25THRSS's Avatar
correct, but I think you also need a different vss
Old Oct 17, 2004 | 11:31 AM
azvolfan's Avatar
I don't think the article said anything about changing the vss. Maybe I should read it again.
Old Oct 17, 2004 | 12:00 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
All you should need is the correct drive & driven gears. About a month ago we swapped the rears in my brothers 1989 T/A from 2.73's to 3.42's. I removed the tranny tailshaft housing and swapped the drive gear and pulled the vss sender and changed the driven gear. His speedo has been right on without a problem.
Old Oct 17, 2004 | 12:39 PM
azvolfan's Avatar
To pull the tranny tail section I'm guessing you have to remove the drive shaft.
Old Oct 18, 2004 | 11:19 AM
Yes.
Also, I just read that article and they did mention something about 90-92 cars needing a "completely electronic" solution. You might want to look into it a little more in depth before ordering anything...
Old Oct 18, 2004 | 11:34 AM
jmd's Avatar
jmd
No he doesn't. He needs drive and driven gears. It's still a 4004 pulse per mile VSS setup that he needs whether he has 2.73 or 3.73 gears.
Again, if you search Tricksters posts, he posted scans from svc. manuals of a lot of the GM factory speedo gear combinations. Once you find those, buy the right tooth count gears, install them, done. Then the car will be setup 100% factory, everything will work as intended, the car won't be "hacked," and the cost is minimal.
Chevy High Performance probably has the wrong gear counts unless they went by GM specs. All online web based speedo gear calculators are wrong per GM installed gears.
The only annoying part about doing the gears is the fact that you have a torque arm. My cars don't. It's an easy job.
-Matthew
Old Oct 18, 2004 | 11:35 AM
jmd's Avatar
jmd
Originally posted by 82CamaroZ28
Yes.
It's a mechanical gear driven electronic VSS. The factory put the same gear counts in a 1989 Camaro with 3.42s as they did with a 1992 Camaro with 3.42s, but the driven gear is a different style and they installed a VSS instead of a speedo sleeve.
Old Oct 19, 2004 | 06:20 PM
25THRSS's Avatar
Right, it has the same pulse VSS, but with the different sized gears you may need a different VSS with an offset shaft. I can't remember the part # offhand, but if you do a search you will find it.
Old Dec 22, 2004 | 09:32 PM
exotikcamaro's Avatar
Car: 1989 Camaro RS
[QUOTE]Originally posted by jmd
i thought it was a 2000 ppm vss??
InfernalVortex
Apr 20, 2021 11:31 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
89newfun
Sep 16, 2015 09:28 AM
