Who is running AFR 190 heads???????
Old May 22, 2001 | 05:17 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I have a set of the AFR 190 straight plug heads. Any of you AFR guys using a shorty spark plug? If so which model? I have a problem with cylinder # 7. It's way too close to the header pipe.
Help!!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Old May 22, 2001 | 06:31 PM
Steves ZZ5's Avatar
Phil,
Here is a link to a thread from a couple months ago, check it out. Look at my very first post in the thread about shortening standard plugs. It's what I had to do, and it works out to a gain of about 3/16ths of an inch. Not much of a gain, but better than what you have now.
https://www.thirdgen.org/messgboard/...ML/007318.html
And to answer your question, Accel doesn't make a "shorty" style gasket plug as of yet.....This much I know. And, I'm not yet aware of anyone ELSE that makes a gasketed shorty style plug.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
CRFred
Feb 7, 2016 11:39 PM
355tpipickup
Aug 19, 2015 10:02 PM
355tpipickup
Aug 13, 2015 07:35 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
