Need a new alternator on the 2.8 v6 .. will anyone atleast help me..please
Old Oct 17, 2004 | 07:27 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Im runnin a system .. amps pushen 1000 watts.. so i need a bigger alternator and i kno it.. i think the system killed it.. so im thinken a 140+ what would be the easiest alt to hook up with not a lot of fabrication.. money isnt an option. I kno my alt went bad because when i hooked up the new battery, it said 13.5-14. volts right away then dropped to 12.... then turned the lights on now were down to 10 and so on.. lol shes shot any opions will be greatly apprieciated!
Old Oct 17, 2004 | 07:51 PM
Car: 2002 SS
Engine: Ls1
???HELP????????
Old Oct 18, 2004 | 05:02 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
we are running a 1000 watts in the 94 with no problems. ai would just go with an OEM replacement, buy one with a lifetime warrenty and be done spending $$$$.
Old Oct 18, 2004 | 06:44 AM
Car: 2002 SS
Engine: Ls1
it might be a connection because it just sarted doing this.. but the lights have always dimmed and im done with it...im gunna call up an alternator place if i can find one
Old Oct 18, 2004 | 11:12 AM
ljnowell's Avatar
If you are running a big system, dont waste your time with OEM replacement alternators, just get a good one so you can forget it. I went through 4 in a year, before i gave up on it. Where I live there is a guy that builds alternators and starters. He took my stock alternator, and for 80 bucks, rebuilt it the best it can be. It tested out at 14x ( I forget exact number) amps, and perfect voltage. I ran my system for another year and a half, with no problems at all out of it. I still have the alternator too. When I did the 2.8 > 350 swap, I couldnt re-use it, at least not easily.
Old Oct 18, 2004 | 03:33 PM
Car: 2002 SS
Engine: Ls1
hmm thats interesting im gunna have my dad check around
Old Oct 18, 2004 | 04:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
autozone has the 108 amp upgrade alt. $60 lifetime warranty. I have only replaced mine once and it was my fault.
I run 1200 watts and also have extra fog/running lights with no problems.
Though you gotta spin the back plate. You remove the screws for the alt case. Then only lift it just enough to spin the case around. if you lift to high the brushes fall and and you gotta take it back and get another. Just say it didn't work.
It is a little bit of work but worth it.
Bazookajoe254
Mar 13, 2007 05:47 PM
steven23
Sep 6, 2006 09:22 PM
crazy3rdgen
Oct 24, 2004 10:03 PM
92GTA
Apr 27, 2004 03:08 PM
Demon Z28
Pacific Northwest Region
Jun 14, 2001 03:59 AM
