What the hell happened?
Old May 22, 2001 | 12:18 AM
pookey's Avatar
I was driving (a little rainy, could be the problem?) today when all of a sudden my car stalled. Tried to start it but it wouldn't turn over. I had plenty of power in my battery but it just wouldn't crank. As soon as I would turn the key I would get nothing. I open my hood and saw nothing unusual. I got back in the car and was about to lose my S*** when I tried it and it started. What the F***? I did notice yesterday that when I gave it some gas it hesistated a little.
88 White Formula 305 TBI With Abosulty Nothing Done To It!
Old May 22, 2001 | 12:29 AM
UVA3rdGen's Avatar
I am no expert but perhaps it was two different problems. The not cranking could be starter heat soak issues and the staling and hesitating could be a broad range of problems ranging from ignition to emission control. I just fixed my stalling problem; EGR valve was not staying shut very well. Doh, well looks like I really was not able to help you much after all....hmm well I can give you this piece of advice I learned today. If you are going to port your heads that are full of carbon deposits wear some sort of mask otherwise you might sneeze continually while trying to post a message.
Old May 22, 2001 | 03:06 AM
Bort62's Avatar
Or have them Mag'ed First.
Back to the Topic, Sounds like an intermittant Loss of contact, somewhere
Not incredibly informative of me, is it...
Its possible the rain caused a Short someplace, as well.
See if you can't duplicate it, Check for loose wires around the starter.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 22, 2001 | 06:03 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Maybe check to see if you have a cracked distributor cap, rain getting in it can cause problems.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
coming soon B&M Quicksilver Ratchet Shifter
Old May 22, 2001 | 07:24 AM
mtx28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by UVA3rdGen:
....hmm well I can give you this piece of advice I learned today. If you are going to port your heads that are full of carbon deposits wear some sort of mask otherwise you might sneeze continually while trying to post a message.</font>
hahaha, good call
and, i had te same problem in my 74.. it would randomly shut off, let me sit several times before i got fed up w/it and handed it over to a 'backyard' mechanic, who said there was a wire shorting the car out everytime it swung against some metal piece.. anyways, look around, maby a cut wire or something(exposing it and causing a short)
  • 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
  • 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
Old May 22, 2001 | 11:21 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
JUST MY 2 CENTS WORTH HERE.
I TOO HAD A STALLING PROBLEM IN MY 83 MONTE. FRAYED WIRES RUNNING ALONG TOP OF VALVE COVER ON PASSANGER SIDE. JUST TAPED IT ALL UP AFTER MAKING SURE THE WIRE WAS STILL GOOD. STILL HAD SAME THING HAPPEN. PUT A NEW DISTRIBUTOR CAP ON, BUT WHEN I LOOKED A THE BOTTOM OF THE COIL (HEI), IT SEEMED ALL RUSTY LOOKING. I JUST SCRAPED IF OFF WITH A SMALL SCREWDRIVER SO THE SPRING GOING THROUGH THE CAP MAKE A GOOD CONTACT. (PUT SOME DILECTRIC GREASE ON IT TOO)
ALSO HAD PROBLEM NOT STARTING. WOULD GO ONE TIME, NEXT DAY SEEMED DEAD, NEXT DAY WOULD START. MAIN FEED WIRE ON STARTER WAS GREEN. ALL GUNKED UP. SANDED IT ALL OFF AND PUT A LITTLE GREASE ON IT BEFORE REASSEMBLY. NO PROBLEMS SINCE.
HERS 90 IROC-Z 350 TPI
HIS 86 TRANSAM 305 TPI (406 AT SHOP NOW)
RS Reaper
Oct 17, 2018 07:52 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
