Indexing plugs WORTH it or NOT?
Old May 22, 2001 | 06:03 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I am currently running Bosch +4 and tomorrow I will be changing plugs to AC Delco stock replacement.
1. Should I spend the extra time and index them or not to bother?
2. Do our cars come with some type of factory spark amplifire? This one salesman told me that they do?
PS. I will be upgrading my ingition and buying a HP coil soon.
Thanks.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
Old May 22, 2001 | 07:06 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have indexed my plugs before. It's a lot of work and I'm not sure If I gained anything. I think it's more important for higher horse applications though I firmly believe in the "every little bit helps" philosophy.
Spark booster? Never heard of it. You should have the standard GM HEI ingnition. Maybe he's talking about a resistor type plug for radio noise suppression.
Also MSD says you should not run platinum plugs with their boxes.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old May 22, 2001 | 08:16 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
<font face="Verdana, Arial" size="2">Originally posted by DANIELEK:
. . . Should I spend the extra time and index them or not to bother? . . . </font>
Why not just file the side electrode back to about halfway across the center electrode. That minimizes any shrouding effects and should be somewhat less sensitive to the orientation of the plugs relative to the cylinders.
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
Old May 22, 2001 | 09:35 AM
bhaas's Avatar
Good idea Norm. I like that. Gonna have to give it a try. Did you notice any difference when you did that? Or have you done that?
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
Old May 22, 2001 | 10:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Doesn't a cut plug wear down faster than an untouched plug?
I indexed my plugs once... no idea if it gave me that 1 HP or not, so now I just eat a lighter lunch & don't index the plugs.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 22, 2001 | 11:15 AM
82camaro's Avatar
Car: 82 camaro SC
If you get up around 600 plus HP, it might help. Or, if you are running some type of boost. In a typical street engine you won't gain anything. Cutting the plugs will just decrease life.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 23, 2001 | 12:05 AM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
What's wrong with platinum plugs and MSD? I've never heard that before.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Jetmeck
Sep 4, 2015 12:29 AM
