Cooling fan switch....
Old May 23, 2001 | 02:33 AM
NOCANDO's Avatar
After installing my headers on my 92 Camaro, I discovered that I accidently damaged the wires to a sensor. A long pin is on the tip of the sensor. A GM partsman informed me the sensor is a cooling fan switch. The sensor is between spark plug 8 and 6. I purchased the sensor. My question is....installing the sensor. Will water gush out after I remove the old sensor? The pin on the tip of the wire...Do I insert it into the sensor???? Help My car is overheating...
Old May 23, 2001 | 07:52 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Yes, you'll loose some coolant - unless you're real quick and have nimble fingers. It won't be much, though. Just remove it and try to catch as much coolant as you can so it doesn't get all over the place. Put your new switch in and hook it up. You may have busted the connector for it and will have to get another, but it just snaps onto the switch...
KAM
Old May 23, 2001 | 08:16 AM
NOCANDO's Avatar
Thanks for the info...I may have to get another connector.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
