brake squeek being a pain plz help!!
Old Oct 20, 2004 | 08:47 AM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
Transmission: 700-r4
My front driver side brakes started squeeking a couple days ago and i took the tire off checked for wear on the pads and they were good. Rubbed some anti-squeak gel on the pads and made the rotor turn and no squeak. Put the tire on and started driving down the road. Started squeaking. Pulled it up in the garage and put more anti-squeak on. Drove around and no noises last night. Was raining today and pulled it out of the garage to come to school and was fine for about 5 minutes then the squeak started again!!! PLEASE HELP!!!!
Old Oct 20, 2004 | 09:41 AM
ede's Avatar
ede
try differant pads make sure piston isn't sticking, make sure bushings bolts go through are free to move
Old Oct 20, 2004 | 02:00 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
This is happening on the right wheel of my LS1 rear end. I've discovered that the piston is sticking and the caliper needs to be replaced. That's probably what part of my next check is going to
Old Oct 22, 2004 | 01:34 AM
sellmanb's Avatar
Car: '86 Berlinetta
check if your "dummy tab" (as I like to call it) is bent down too far and causing the squeeking noise. Otherwise I'd suspect a sticking piston.
Old Oct 22, 2004 | 08:59 AM
david_0161's Avatar
Car: 89 Camaro RS
Engine: 305 L03 V8
If the piston was stuck would it still make a noise when i rotate the tire when its jacked up??? Totally lost here and cant get pads till wednesday and its driving me nuts.
Old Oct 22, 2004 | 10:24 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
possibility that the pads are glazed over......
or stuck piston on the caliper...
gta892000
Aug 11, 2019 11:16 AM
dbrochard
Sep 19, 2015 08:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
