Could this be causing my problems?
From: First one out of liberty city, burn it to the ground
I was pulling the intake today to look for the vacuum leak, and i noticed hey my EGR isnt all the way on...i tried tightening it but the bolt hole is stripped. Could this be causing my stalling and none-idline condition? After this its going to paradise chevy by me to get the speedo done, all the emissions hoses and egr controller replaced, get a new MAF system and TPS, then more...so i need it to make about a 30 minute drive on the freeway. I know the emissions is causing some of the problem, but could this be causing the non-driving problem? help me!
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
1989 Firebird
Car: yep
Engine: uhuh
Transmission: sure does
yes it could, of the 2 passages on the EGR valve, one is a BIG vacuum leak if exposed. The other is an ex. leak.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
