2.8L,MPFI engine lopes during idle
Old Oct 21, 2004 | 12:03 AM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
Hello,
Can someone out there tell me if they have had this problem with there V6-(2.8L mpfi)..The engine idles at fast idle after start up then gradually decreases in RPM-(normal);then , around 500rpm to 800rpm ,the engine begins to rise and then lower speed and sometimes it seems like it wants to stall.When the accelerator is depressed quickly,the engine rpm drops alot then picks up(it isn't a quik throttle response).Spar plugs were changed,distributor cap and rotor next,then fuel filter.
Can someone direct me in the right direction?
Thanks guys!!!
Attached Thumbnails 2.8L,MPFI engine lopes during idle-1987-blue-eagle-inverted
Old Oct 21, 2004 | 11:28 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Check the timing.
Old Oct 22, 2004 | 01:01 AM
sellmanb's Avatar
Car: '86 Berlinetta
if you didnt change spark plugs in that scene as well then I'd suggest looking at that as well.... my car did the same when it needed a new O2 sensor also...
check your TPS and IAC, there's a tech article on it, you can find them from the main page.
Old Nov 8, 2004 | 12:01 AM
sellmanb's Avatar
Car: '86 Berlinetta
also check and make sure everything on the dizzy is working properly.
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
BurlyChev
Aug 16, 2015 09:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
