Cam thrust plate problems...still
Old May 22, 2001 | 02:46 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I finally got the correct thrust plate for my new block today, but it was too thick!! I ground it down, but I went slightly too far and broke it. Anyways why would it be too thick?? Am I missing something here??
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Old May 22, 2001 | 08:59 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Paul, was the block machined for the thrust bearing? My last one I used a cam button instead.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old May 23, 2001 | 09:26 PM
Car: 89 IROC-Z
Engine: 383
Ok here's the deal....I didn't use the bearing, just the plate that bolts to the front of the engine over the cam, but like I said it was too thick. Would I be able to just use a cam button instead?? That kind of worries me. Also is there a possibility that there would be a different cam gear for this block than my last one. This is a four bolt main block and the last one was two bolt mains.
--RPM Racing--
Old May 24, 2001 | 11:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Turf the factory's bizarre roller hallucination, go with what's been working for decades. Use a button.
ICON Motorsports
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
LT1Formula
Nov 16, 2015 01:13 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
gwade12
Aug 8, 2015 08:17 AM
