How much torque to turn rotating assembly?
Old May 22, 2001 | 02:44 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
My machinist said that it should only take 20 ft/lbs to turn my crank and pistons in my new motor, but it's taking 30 to turn mine. Is this a problem??
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Old May 22, 2001 | 04:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is no exact value. 20 seems low to me for a street build, maybe reasonable for a race-only one. 30 would seem reasonable to me for a brand-new motor. It depends alot on what rings are being used, and how the block is honed; and on how much bore clearance the pistons have.
ICON Motorsports
Old May 22, 2001 | 04:44 PM
mtx28's Avatar
when i turned mine over by hand it was pretty hard.. im sure it was more than 20..
  • 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
  • 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
Old May 22, 2001 | 04:54 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I don't think you can globally say a number. Ring tension, piston to wall clearance have a lot to do with it. I don't think GM ever provided a number (or even a range) and I would think their assemblies should have been consistent enough to do such a thing if it were possible on a stock motor.
Old May 22, 2001 | 08:28 PM
Car: 89 IROC-Z
Engine: 383
Ok well I think my machinist is going to try to tell me something is wrong, but I don't know. I'm going to try to convince him to come over and take a look at it. Anyone else have an opinion on this??
Old May 22, 2001 | 09:09 PM
Bort62's Avatar
30 Sounds perfectly reasonable, To me.
As long as you used your plastigauge, and were careful, You should Be In Good Shape.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 15.26 @ 87.0
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 22, 2001 | 09:16 PM
ede's Avatar
ede
i just finished a 350 last saturday. i used a regular length 3/8 ratchet to turn the crank socket. took a good bit of effort but i could do it. i'd guess more towards 30ft/lbs.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 23, 2001 | 09:23 PM
Car: 89 IROC-Z
Engine: 383
Ok well then here's a good question to help me determine if it's too tight. How much space should there be between the rods in the crank journal because I have next to none and I mean none. Also if someone can please read and reply to my post on the cam plate it would be greatly appreciated.
--RPM Racing--
Old May 23, 2001 | 09:32 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
I have had my new 350/360hp crate motor on the stand for a few months. I would say its
at least 30 ft/lbs to turn it.
Tom K.
84 Z-28 M5 305 L69 HO
pulleys,coil,3:73(stock)
Jet chip, fan switch,
Al dshaft,1.6 rockers,
LCAs and brackets,BFG DRs
14.20 @ 96.74 2.02 60ft
Old May 24, 2001 | 10:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
On the rod side clearance, I like to see about .015".
ICON Motorsports
Old May 24, 2001 | 12:46 PM
Changa2's Avatar
I just completed my 383 and I read 300 to 350 In# 0r call it 25-30 ft#. It was hard to get an exact reading because it wanted to jump a bit just as it broke loose. This is w/o cam or heads installed.
After boring I had a regular hone first and then a 'soft' hone which slightly breaks the peaks. This results in a slightly smoother finish.
Looks like we're in the ballpark. This is my first build and I was curious about that as well.
[This message has been edited by Changa2 (edited May 24, 2001).]
Old May 24, 2001 | 12:55 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
what rb said. The spec is from .012 to .016 side clearance. If you don't have it you will put a lot of metal in the oil right as you bust it off. It is pretty hard on a new motor.
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
mhatfield 14
Oct 24, 2015 07:48 AM
CORV3TT3
Aug 23, 2015 11:26 AM
