Tune up questions
Old Oct 23, 2004 | 01:02 PM
Boingo's Avatar
Car: 92 Convertible
Engine: V8
Tune up questions
Would appreciate some tune-up advice. Car is 1992 convertible with 305 V8.
1. What plugs should I use?
2. Should I use OEM plug cables, distrib cap & rotor, or is Pep Boys OK? I know on my 280ZX only OEM caps & rotors would work right.
Also, I am getting some noise out of my stereo. Maybe I need special plugs and cables.
Thanks for any advice!
Brian
Old Oct 23, 2004 | 01:23 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
as far as tune ups go i just use AC delco plugs. and i use bog wanner 8 mm wires i dunno if the 92 had a HEI cap or not but if you do they sell kits for a new cap coil and rotor and wires for like 100 bucks for MSD or mallory.
Old Oct 23, 2004 | 04:56 PM
rlrepitman's Avatar
Car: 1987 Camaro SC
Engine: LG4 305
Transmission: TH700R4
Brian,
You should be fine with a wire set, Cap & Rotor, and plugs from a chain Auto Parts store such as Pep Boy's, Kragen, or Auto Zone. However, I strongly recommend using the Factory AC Delco sparkplugs that are listed in your owners manual or Tune-up sticker under the hood. They should carry AC Delco plugs. All the other parts can be aftermarket brands if you wish, which should save you some money. I've used their parts on my parents 1992 RS with LO3 305 V-8 and my 1987 Camaro SC with LG4 305 V-8 with great success.
Old Oct 23, 2004 | 07:11 PM
ljnowell's Avatar
You dont need 60 dollar plug wires, thats for sure. I would recommend getting a parts store set, 8mm. Be sure to get the cap and rotor with brass inserts.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
