CODE 44 help please!!!
Old May 21, 2001 | 10:59 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
What should you look for with a code 44 like what has to be replaced??
thanx for the help
86 Z28:
350 vette
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
Old May 21, 2001 | 12:35 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
come on guys i need some help!!!
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old May 21, 2001 | 12:40 PM
rezinn's Avatar
44. Oxygen sensor lean
What is happening to your car? Does the code go away? Does it affect performance at all?
Old May 21, 2001 | 12:52 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
it doesn't do anything that i noticed. i just haveing a problem with my battery not charging and i did a a short in the tail light but i fixed it. could a short set it off?
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old May 21, 2001 | 12:59 PM
rezinn's Avatar
I don't know how a short in your tail light would cause your 02 sensor to show lean :P
I think most of the time it is a self correcting problem, you are just being informed that you aren't getting enough fuel. Maybe you need to check that out. What size injectors are you running on the new engine? If you had a 305 in your car before you might be depriving your engine of fuel if you didn't upgrade your fuel system.
Old May 21, 2001 | 01:32 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
my car is a carb maybe it was the battery was low and the electric fuel pump was pumping like usaual and it wasn't getting enough fuel?? thanx for the help
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old May 21, 2001 | 02:47 PM
rondubbs's Avatar
when i had a code 44, all i had to do to get rid of it was replace my old carbon clogged o2 sensor, try it.
Old May 21, 2001 | 02:51 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
the 02 sensor i got last summer. its not even a year old. and last time it was bad it was a code 13.
im lost now!!!
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old May 23, 2001 | 09:57 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Do you have the Tuned Port setup or a carb?
Old May 24, 2001 | 10:22 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ahhh, MikeInAZ is in the house...Mike is better known as the "King of the 44" Club
Old May 24, 2001 | 10:47 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
it is a carb and also my choke light is on.
any help Please?
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old May 24, 2001 | 05:28 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Hey....8Mike9....buenos dias.
FORMER King of the 44 Club. After 10 months I solved my 44.
To the other Mike: I'm not real sure on the carbed setup but consider the following possibilities, probably in this order.
Fuel filter.
Vacuum leaks from hoses to carb.
Most important and what took me 10 months to figure out. Make SURE manifold bolts are tight. My middle 4 were so loose I could turn it with a 1/4 drive socket = major vacuum leak. Other causes:
02 sensor.
Plugged Cat.
Plugged Muffler.
Air diverter valve malfunction (unlikely).
The 86's also had a bugged PROM that would set false 33 and 44 codes.
Old May 24, 2001 | 05:44 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
i changed the 02 last year and that gave me a code 13. i think it is my fuel filter it is old i know. im gonna check.thanx for the help!!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
