1991 Caprice 9C1
Car: Z28
Engine: 310
1991 Caprice 9C1
Found one in the paper for cheap, says its a 350, former cop car. Just curious on engine specs and transmissions in these cars. If anyone knows.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
DOn't know much. I do know, however, they are 350 TBi. They have the police injectors, FWIW.
Probably a 700r4 transmission.
Someone can probably elaborate better on it.
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Mine is a 93. Had the 65 lb injectors. I was never able to pin down exact cam specs, so used a different cam. The block was a 2 bolt main. It also had a block heater installed in one of the freeze plug holes that blew out on an over-rev about 3 weeks ago. Fortunately it was an easy fix. Thats about all I know about them-
S-D
S-D
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is a regular LO5 with larger than stock injectors. There are two versions of injectors for the LO5. There are the standard ones (55# IIRC) and the cop car injectors at 65#. The PROM tunes are also slightly different. Basically it is 220hp and 300 or so tq. The TBI unit and intake are the same ones found on LO3's. They suck. In equaly suckiness they have large chamber swirl ports and a weak cam.
Car: 1991 RS
S-D
You might find a bit more information at http://www.impalaclub.com/naisso/for...asp?FORUM_ID=7
You might even find some familiar members.
Car: '90 RS
Engine: 377 LSX
Originally posted by swerve-driver
Dang dude, are you not a moderator on the TBI board? Is the actual TBI unit that bad? I am using a stock casting on a 350 with 65# injectors and getting 13.8's. Does that also suck?
S-D
S-D
