failed emissions nox test in texas Help!!!!
Old Oct 20, 2004 | 08:32 PM
TEXASPLANOBOY's Avatar
Car: 1992 CAMARO RS
Engine: 5.0 TBI
Transmission: AUTO
my 92 camaro 5.0 tbi failed dallas texas emissions test......does anyone know how the air pump effects this test...
at idle i do not feel any air when i pull off the hoses at the air pump...... when does the valve that controls it kick in should i feel air at idle through the air pump?????
i also replaced the fuel injectors and rebuilt the throttle body,and new fuel pump assembly in tank.. the car runs great but during the failure of fuel system it ran rich because ports at map and egr were clogged forcing engine to run rich......
i passed on all tests except nox gas...
emissions tester suggested replacing catalytic converter...
Old Oct 20, 2004 | 09:20 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Well you might replace the cat if you feel like just throwing money at it. But the cat has an air tube, right? If I were in your place I'd probably replace the pump frst. Oh and take off your hoses and blow a little compressed air through them to take care of any clogs maybe?
Old Oct 21, 2004 | 05:14 AM
contactpatch's Avatar
Engine: sbc 350
The usual emmisions tricks would apply here.
Fix the obvious problems, first.
(running rich, fails NOX ?, interesting, ,,
also, does this car have an air diverter valve?)
for NOX
make sure egr is working, if you have it...
move timing back a few degrees, will lower nox,
might raise HC, CO....
five percent ethanol in fuel, if the two above don't work
for HC, CO
make sure ignition is working at its best
make sure air pump is working, if so equipped
make sure car is completely warmed up, for test
Old Oct 21, 2004 | 10:47 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you have a cat back exhaust on it, there is most likely your problem. To fix it, you need to enlarge the vacuum hole in the EGR valve. This is not easy as it is a wire drill size. But the problem is the TBI system needs a little backpressure to open the EGR valve, by drilling the hole a few thousands it adds a little more vacuum assist. When I've done this it will take a car that is showing 1300 NOX down to 200-300.
HTH
Old Oct 21, 2004 | 01:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The other route is to replace the factory valve with an aftermarket non-positive-pressure type.
Another common cause of EGR malfunction is plugged up EGR exhaust ports.
Old Oct 22, 2004 | 06:11 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
Hey TEXASPLANOBOY, I live in McKinney and there is a guy up here that is a whiz on emissions. He has helped me on both my 88's. PM me and I'll get you his name and location or give you my phone number to talk. He specializes in emissions problems.
Old Oct 25, 2004 | 01:17 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Hey dual_88s - I'd like to talk to that dude as well. I finally got my 383 SuperRam to pass the emissions test - LEGALLY! - but just barely. My CO was right at the limit for both speeds. Another .01 and I'd have been in trouble. Surprisingly enough, the NOx and HC were both about midrange. So I'm trying to figure out what's wrong.
Would this dude be a decent guy to talk to? I'm in Plano, so not too far away at all......
Old Oct 25, 2004 | 02:26 PM
dual_88s's Avatar
Engine: 305TBI
Transmission: AUTO
Real decent dude. He isn't going to do anything illegal but he knows what it takes to 'fix' it to pass the tests. I bought my second car from CamaroWorld in Richardson last November and I had to take it in this month for the first time for a new sticker. Took it to him and it passed first time...said it was real clean.
I haven't done anything since I bought it except a new top.....
My son took his (the other 88 ) to him and it also passed....course it was OK last year and we haven't done anything to it. Although when we first bought it, it took 6 tests to get by.....changed cat, tried all of those "guaranteed" to pass chemicals, etc. Turned out I had the wrong size injectors...engine had been swapped from 305TPI to 350TPI and wouldn't pass woth 305 injectors....
He has told me that if I ever have problems passing emissions, that is what he specializes in.....fixing them.
I know him through the local soccer association....we both referee games.
You can call me if you want....2-544-1348
Hotrodboba400
Dec 10, 2019 07:07 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Veaceonee
Sep 29, 2016 08:15 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
