MY CAR WONT START 89 TPi
Old Oct 24, 2004 | 08:44 PM
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
1989 5.7 TPi GTA. Car wont start. Engine cranks, but I'm not getting any spark. Fuel pressure is good, coil and IGN Module are good also(swapped with two new ones I had), all fuses good, all wires to distributor and coil have power (accordingly). After all testing still no spark can anyone please help its gettin colder here which means its harder to work outside. Thanks in Advance.
PS -- is there some sort of in-line fuse, or fusible link, thats not in the fuse cluster under the dash that could have blown? If so where is it located?
Old Oct 24, 2004 | 09:29 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Should be a ECM Fuel pump fuse between the battery and radiator on the core support
Old Oct 24, 2004 | 09:30 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Have you checked for spark at the coil?
Old Oct 24, 2004 | 09:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the pick-up coil in the distributor? Also in answer to your P.S. the answer is no.
Also if he is getting good fuel pressure, the 20 AMP in-line fuse by the battery wouldn't be the problem.
Old Oct 24, 2004 | 09:56 PM
Axle/Gears: 3:73
No ihavent checked the pick up coil or for spark at the coil.....but I checked all the wires none had a spark. How do I check the Pick Up Coil?
Old Oct 24, 2004 | 10:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here you go!!!!!!!!!!
Old Oct 25, 2004 | 01:48 PM
Axle/Gears: 3:73
Checked resistance of pick up coil today.....my meter read a steady 757 ohms. So I'm guessing thats not it? I was really hopping it was. oh well back to the drawing board.
Old Oct 25, 2004 | 03:04 PM
mavis_1's Avatar
Car: 89 iroc convertible
Engine: 305 tpi
try a coil. Mine was the same way. The coil would test good. But! It was bad. The terminals were shot and when you put pressure on them they would make contact. Maybe this will help you?
Old Oct 25, 2004 | 03:41 PM
Axle/Gears: 3:73
Eureka! I got it. When I went to re-assemble the module to the pick-up coil connector I noticed that one of the metal tabs on the connector was broken. The pick-up coil itself is good but the connector is bad...so I replaced the connector with another one I had lying around my garagere-assembled and bam! it started right up. Thanks everyone for your help, it is most appreciated.
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
jharrison5
Aug 19, 2015 05:53 PM
drathaar907
Aug 6, 2015 04:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
