Window stuck halfway down
Old Oct 24, 2004 | 04:27 PM
Faded's Avatar
Car: '91 Firebird
My the motor in my drivers side window has siezed up while halfway down. Is there a manual way to roll it up?
Old Oct 24, 2004 | 05:52 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Is it half way down, or half way up?..guess it depends if you're an optimist or a pesimist.
Old Oct 24, 2004 | 07:54 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Depends on whether it is raining or not......
There is no manual way. Unless you pull the door apart, remove the motor, and then jam it up. But, if you are going to go that far, might just as well put the new motor in (if that is what it needs) and be done with.
Old Oct 25, 2004 | 12:38 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Try pulling up on the window, when you push the switch. Then take the door panel off and lube the slides and guides with grease. If that doesn't help test the switch, check for current at the motor. Then go from there.
Fireslash
Apr 11, 2016 06:43 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
tmellott89
Oct 14, 2015 02:06 PM
kkirch15
Sep 30, 2015 04:44 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
