A homemade "cool can" for my fuel
Old May 24, 2001 | 06:19 AM
JPrevost's Avatar
Car: 91 Red Sled
I tripped over this on some off road guys website, it looks easy enough to build.
Anybody have any opinions? What exactly is it good for? I've heard that cooler fuel is best for performance, yes or no and why.
, Jon (350 TBI!)
91 Red My website
Old May 24, 2001 | 06:52 AM
bhaas's Avatar
Well you have to put alcohol and ice in there to really cool the fuel down. The reason for cooling it is, it will make the fuel more dense, thereby getting more fuel to the motor. And we all know that more fuel means more power
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
Old May 24, 2001 | 07:20 AM
ede's Avatar
ede
i made one once for a 69 z/28 we were racing back in the 80s. all i did was take a piece of aluminum fuel line and wrap it around a fence post and stick it in a can. i stuck the ends of the line thru the can and used RTV to make a seal. after i had it done i wished i'd used copper or steel line so i could of soldered it, but it worked.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 24, 2001 | 11:26 AM
JPrevost's Avatar
Car: 91 Red Sled
Is there any real point to making the fuel more dense? I mean if you have more fuel then won't the ecm take that into consideration and lean it out a bit?
, Jon (350 TBI!)
91 Red My website
Old May 24, 2001 | 12:54 PM
cfabe's Avatar
Not if you dont run a computer.
Old May 24, 2001 | 03:35 PM
Jester's Avatar
Cooler fuel means a cooler intake charge, which in turn means more power.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 24, 2001 | 10:23 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
it's a good idea and it works well. cold fuel will flow faster to start with as well as hold pressure better. cold fuel also has the same effect as cold air. as it gets cold it compresses which is the only way liquid compresses is by cooling it. same idea with checking trans fluid when it's warm. expands when it's cold. one spray from an injector of 20 degree fuel holds more explosive capability than 80 degree fuel. on a high pressure fuel system like tuned ports, this is very helpfull keeping fuel temps down. it does have very little effect on air intake charge temp though. another advantage is the ability to use more advance on the ignition timing since it takes longer to evaporate and burn.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
