1978 350 heads on my 1992 305
Old May 23, 2001 | 09:28 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I know I would have to get new valve covers, but what about a new intake also? Would my stock exhaust manifolds bolt up to the heads? Would I would have to mill them down a bit to get the compression back up? I was thinking about getting a TBI Edelbrock intake would this work or would I want to go with a carb intake then buy a TBI adapter?
Old May 23, 2001 | 09:34 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Just for starters, the center intake bolt angles are different. (not that big a deal, just buy a different manifold)
Then if the heads are not drilled for 7 ex. bolt holes on the pass side, the ex. manifold won't bolt up.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited May 23, 2001).]
Old May 23, 2001 | 10:04 PM
So it won't work OR it will work with an older carb intake
Old May 23, 2001 | 10:08 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
the intake part is easy, just buy an older style intake....yes.
The ex. side is where you are going to have a problem. (with stock manifolds)
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old May 24, 2001 | 11:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those heads are 76cc; so you'll end up with a compression ratio maybe less than 7:1. It's not realistic to attempt to mill them enough to lose 20cc of chamber volume.
Don't even bother unless you're running at least 12psi of boost.
ICON Motorsports
Old May 24, 2001 | 02:20 PM
Okay I have to have all of my smog equipment working. Is there any way I could buy some 350 heads from a 1987 or later 350, what size combustion chambers do those have? Will the Edelbrock TBI intake bolt up to those 1987 350 heads? Will my exhaust manifolds bolt up to those heads?
Old May 24, 2001 | 10:57 PM
okay sorry to bother you all again
Now I can get 1989 350 chevy full size truck heads. What size combustion chambers do these heads have? Will my stock exhaust manifolds bolt up? Will my intake bolt up?
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
st.evel07
Aug 13, 2015 06:15 PM
