Roller lifter conversion for older block.
Old Oct 26, 2004 | 07:47 PM
F-1Rodder's Avatar
I'm new here, don't know if intros are in order. I am running a gen I front clip and motor in my F-1 pickup.
I want to convert my older 350 block to roller hydraulic lifters. I can buy a conversion kit from Comp Cams at about $600. I am interested in knowing if anyone out there has done this.
Also, I have heard that it may be possible to use roller lifters from 3.0-3.8 V6 motors and a bridge from a 305. Do any of you know about this?
My motor is an early 70's block, now modified to 383. I have burned up one cam early in its career and would like to go to the roller to avoid break-in problems and to get quieter operation.
Will the roller hydraulics be too heavy to support a Comp Cams XE268H style grind with its steeper than stock ramps? How about springs with the heavier rollers?
Any comments you have will be appreciated.
Thanks, F-1
Old Oct 26, 2004 | 08:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it can be done.
Yes it has been done, many many times.
Yes you can get one as small as a XE268; yes there are springs that go with such things. Just use the ones that go with whatever cam you pick. For example http://www.compcams.com/Technical/Cu...ML/128-169.asp scroll down to page 138.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
