Fuel Lines
Old May 26, 2001 | 07:42 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Fuel Lines
Ok I am hooking up the Hot 305 I am building. I am having a problem with the hard fuel lines. The lines are too short to fit just right. Can I splice in rubber fuel lines to get more play???
Brian Felts
1989 Camaro RS
305 .030 over
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter LETS PLAY FORD!!
Old May 26, 2001 | 07:50 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
Rubber lines are OK with carbs, but not for fuel injection (unless directly specified as such). Why not get some fittings, hard line, and a flare tool and bend up your own? I've done it with brake lines, and it's not very hard. Looks cleaner too. If you are going to race your car I think the NHRA has a rule against more than 12" of rubber line in the engine compartment.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
