Rev limit?
Old May 26, 2001 | 12:33 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
Rev limit?
hey i gotta 1984 pontiac trans am with the L-69 305 HO
and i was wondering how high could i rev it like when im shifting and still not break anything?
Old May 26, 2001 | 11:00 PM
Vader's Avatar
Matt,
Welcome aboard!
With a basically stock L69 in good condition you should be able to safely shift at 5,000 RPM, but the torque at that RPM will have fallen off to the point where you should have shifted long before that.
Considering the flare on shift and the factory cam and valve springs, their red-line of 5,200 RPM is pretty accurate for repeated use. You might be able to get away with a few excursions into higher RPM ranges, or you might send rods through the case at lower RPM. It is highly variable depending on the condition of the engine and load at a given RPM.
Its your engine, and you're driving....
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
