Verification of TDC...................
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Just to be sure I'm okay, if my motor is at TDC for cyl #1, how many CW turns of the crank will it take to return back to TDC for cyl #1?? I believe its 2 since the ratio of cam gear to crank gear is 2:1.
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Phil87IROC
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're at TDC of the compression stroke and you want to return to TDC of the compression stroke, you'll have to turn it twice. One turn will return you to TDC, but not on the same stroke.
gixxer92
Sep 1, 2015 04:32 PM
