Engine makes Squealing Noise
Old Oct 30, 2004 | 02:32 PM
Magician's Avatar
Car: 1989 Camaro
Engine: 2.8L V6
When my car is idling, it makes this squealing noise. It sounds like plastic rubbing against each other. I lifted up the hood and it looks like it's coming from the engine area, where the belt is moving. What could cause that noise? How do I fix it?
Old Oct 30, 2004 | 03:16 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like a belt slipping. Just tighten it up a bit, or get new ones. Could also be your water pump going out on you.
Old Oct 30, 2004 | 04:02 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Is it this squealing primarily at low(er) rpm's? Or is it consistant throughout the rpm range?
Old Oct 30, 2004 | 04:14 PM
Magician's Avatar
Car: 1989 Camaro
Engine: 2.8L V6
When I'm driving on the highway, I don't hear it. The only time I hear the squealing is when it's idling or when it's stopped. When I hit the gas I don't hear it.
Old Oct 30, 2004 | 04:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Take a piece of heater hose and stick it in your ear and probe each of the accessories. Water pump, alternator, power steering. Try to isolate it.
Old Oct 30, 2004 | 05:43 PM
Magician's Avatar
Car: 1989 Camaro
Engine: 2.8L V6
I went to my car to check the belt tensioner indicator and it looks a little wierd. I don't know what to make of it, so I'm attaching a file with a picture of what I see on the indicator. Let me know what you think.
Attached Thumbnails Engine makes Squealing Noise-belt-tensioner-indicator.jpg
Old Oct 31, 2004 | 04:34 PM
Magician's Avatar
Car: 1989 Camaro
Engine: 2.8L V6
Does anyone have any insight to my picture above?
theshackle
Sep 17, 2020 08:26 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
