Temp Gauge Neddle Is Off The Gauge!!
Old May 27, 2001 | 12:26 PM
CamaroLuvnPunk's Avatar
Hello,
When I bought the car my temp gauge needle was past whatever could possibly be!! I was wondering what could be wrong with it? And what kind of screwdriver do I use to get the glass open? I have the old style tach setup with speedo going up to a wooping 85 MPH ( I can't tell ya how many times I have buried that thing!! )
Any and all help is needed do to the fact that summers coming. I would like to know when my car is going to overheat rather then seeing white steam come out of the hood.
Erik
1983 Berlinetta Camaro with a 305 4brrl Carb.... soon to have a bigger carb,intake, and cam.
Old May 27, 2001 | 12:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Make sure that the sender wire is actually connected to the sender. If I remember correctly, the oil pressure and coolant temperature gauges will max out if the wire is disconnected, or will read zero if the wire is grounded.
Old May 27, 2001 | 01:30 PM
mjdoyle's Avatar
that is correct... your wire probably melted to the manifold or something.. check btw the 1 and 3 cyl's on the passenger side near the manifold
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
gta892000
Sep 16, 2015 12:37 AM
