steering wheel VERY stiff
Old Oct 31, 2004 | 09:18 PM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
ok i have no clue whats goin on i just recently filled in power steering fluid in my car and it was well yesterday and now tonight i turned on my car n tried to drive it and the steerng was sooo hard to turn or steer this had been happening alot latly wat could be the problem ??? i do need to get my brakes done but i kno thats not part of the problem or is it? someone help me out
Old Oct 31, 2004 | 09:46 PM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
Is the fan belt going around the power steering pump still? maybe some fluid dripped onto the pulleys when you filled it and it helped it fly off.... I would check there first
Old Oct 31, 2004 | 10:00 PM
MoroteZ28's Avatar
ok ill hafto check it in the morning right now i gotta wait till my mom gets home so i can get to work i gotta take her neon to work lol
Old Nov 1, 2004 | 08:15 AM
MoroteZ28's Avatar
ok i checked under the hood this morning and the belts were fine they were in place but i noticed somthing i took out the dip stick to see if there was any power steering fluid and there was none! there was a fresh puddle of the Power steering fluid on the street right below the box could this be the hoses? i checked for a lil bit couldnt really see how it could be leakin but i think it should be the hoses wat do u think ?? and is it easy/ cheap to fix ?
Old Nov 1, 2004 | 10:18 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah, its probably the pressure hose that has gone. I had one sheer off of the pump (looked like it was still connected but if you pour fluid in it, it poured straight out ).
Old Nov 1, 2004 | 01:12 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
The pressure hose will run you around 20$ or so at a local parts store. Just make sure you put the O-rings on the end of the lines. You would be suprised how many people come back to me (at advance) with hoses saying they leak...of course they didn't install it right.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
