Idle, speedo and Steering problem.
Old May 26, 2001 | 06:26 PM
DiZmAc80's Avatar
Got a '91 RS 305 with a couple problems.
First, my speedo has a mind of it's own. It works about 30% of the time and even then it will lazily drift up and down. Baisically it's useless.
Second, every couple stoplights I'll be sitting there and the idle will drop just below 500rpm from about 500rpm and the car will begin to shake.
Last, whenever I park, turning the wheels to the left all the way to lock, there's a clunk or two immediatlty when I go to turn the wheels back strait.
I'd appreciate the input, and maybe give me an idea of the costs i'm looking at to fix these.
Old May 26, 2001 | 07:50 PM
Biochem's Avatar
Car: 2002 SOM z28
Sounds like an electronic problem with the speedo. I'm not 100% sure, but I don't think they use a cable like the older models do.
What size tires are on the front? Is it lowered? Have a friend turn the wheel and take a look for yourself to see what it's hitting.
The idle below 500 rpms will shake pretty badly. Is it throwing any codes? That would tell you if there is a problem with a bad MAF sensor or something. Carb cleaner does wonders for poor idles...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old May 26, 2001 | 08:39 PM
Belker's Avatar
A 91 RS would not have any cables to the instrument cluster.
Old May 27, 2001 | 01:51 AM
Vader's Avatar
DiZ,
Since you apparently didn't perform a thorough inspection of the car when you first looked at it (other post) you need to start from square one to find out the condition of everything.
With any newly acquired vehicle, it may be impossible to know how it was treated in its former life. Unless you have copies of all the maintenance records, you really don't know how the vehicle was maintained. The seller might have said that he/she "always" changed the oil, and that it was "just tuned up" or "just had brakes", but what was included with the tuneup, and exactly when were the brakes replaced? It's easy to forget dates and mileage, and that tuneup that was "just done" might have been almost a year ago. Because of this, you need to treat any newly acquired vehicle like no service has been done. Take a look at everything. That "tuneup" might have been spark plugs and a spray can of carburetor cleaner - hardly a tuneup by accepted definition. That "brake job" might heave been front pads, with no regard for calipers, wheel bearings, brake cables, and the master cylinder. A "rebuilt transmission" might have been a new servo and fluid. Unless you have a hard copy of the repair records, don't presume the previous owner had any idea of what has been done. If you have repair records, you are one of the fortunate few. Most of us get just what we see, and nothing extra. Sometimes we get even less.
Unless there is some obvious glaring problem, it will be beneficial to first perform the routine service that should have been done for a vehicle of that age and mileage. For a small investment in parts and supplies, and some of your time, you can do some meaningful work and learn something about the mass of metal that you will trust with your life.
Spend a little money and a little more time in, around, and under the vehicle to learn its secrets. Start with a thorough inspection and routine tune up service. After this, many of the little problems you are experiencing may be gone, and any other problems you may encounter will be easier to diagnose since many of the questions and variables will be eliminated.
TUNE UP SERVICE
Perform a basic tune up and general lubrication. Chances are that even if these services were done, they weren't done completely. The factory owner's manual outlines the services necessary at a given mileage or age. If you were lucky, you got an owner's manual with your car. If you were even more fortunate, you have a factory service manual for your vehicle. This goes beyond the outline found in the owner's manual and into detail about the steps to be performed for routine service. It will also become invaluable for troubleshooting and repair of nearly anything you might encounter while you own the vehicle.
Start with a basic, thorough tune up service. It's not just changing the oil. This is a generic outline of GM recommended service procedures and intervals. Verify the correct interval an procedure with your owner's or shop manual.
A basic tune-up MUST include:
* Cooling system inspection;
* Clean or replace spark plugs;
* Ignition wire testing;
* Distributor cap/rotor (if you don't have the OptiSpark);
* PCV valve cleaning or replacement;
* Air filter;
* Cleaning the IAC;
* Check Throttle Position Sensor voltage and adjust as necessary.
* Check/adjust minimum air rate;
* Check/adjust timing;
* Code scan;
If you have a fuel injected engine, there are a few more steps that must be performed to ensure correct fuel system performance.
The proper steps in fuel injector system service are:
* Check fuel pump operating pressure and volume.
* Test pressure regulator for operation and leakage.
* Flush entire fuel rail and upper fuel injector screens to include pressure regulator.
* Clean fuel injectors.(* if necessary)
* Decarbon engine assembly.
* Relearn onboard computer.
If there are problems with the fuel injectors, no amount of "tuning" will correct it short of an injector cleaning. This is very rarely solved with the fuel additives that advertise the ability to clean injectors. These are probably best used as maintenance products, to keep clean injectors clean. Once an injector is beginning to fail, it's usually too late for any such product to be successful. The relatively low cost of these additives makes it worth at least trying, but don't expect it to cure all of your problems. If the injectors react well to the fuel additives, consider yourself one of the fortunate few. Most of the time, the injectors need to be removed for complete cleaning.
Once you service all the parts and systems that need attention for a car of your mileage, most of your problems should be non-existent.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 27, 2001 | 08:45 PM
Rob90TA's Avatar
Damn, Vader! How long did it take you to type that?
Jorlain
Aug 24, 2022 05:11 PM
Wade787b
Sep 29, 2015 01:15 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Sep 4, 2015 07:57 AM
mike_c
Aug 27, 2015 04:32 PM
