Engine build what should i expect
Old Nov 1, 2004 | 11:01 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok guys, i'm hoping to pick upa used corvette 350 TPI.
I know a guy who has one with 75k miles on it and selling for $500. COmplete.
Now i wanan use the thing for a while unti i can get what i need.
But i wanan fully port and polish the heads.
run maybe 10.3:1 compression, and a 700-r4 out the back thats rebuilt.
I am thinking maybe a LT1 intake or some other sort to pick up the high end torque.
I want a reasonable high lift cam, nothing too loby, but i want you to be able to hear the lobes when i drive by.
So if i got a LT1 intake on a block running 10.3:1 compression, iunno, decent duration cam, i've always liked lt4 hotcam, and fully ported and polished aluminum corvette heads. Plus a rebuild 700-r4 out the back. What could i push out the wheels?
Shane
Old Nov 1, 2004 | 11:22 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Sounds like a good setup although I dont think the Lt1 intake is worth the trouble, I would rather use the HSR. But with that setup I dont see why you couldnt make around 375hp at the fly and maybe 320 or so at the wheels. Good Luck.
Old Nov 2, 2004 | 04:49 AM
ede's Avatar
ede
why don't you get the engine then come back and waste everyones time answering your questions for a project that you'll never start of finish.
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
