valve springs
Old Nov 2, 2004 | 02:54 PM
red85berlinetta's Avatar
valve springs
hey guys i just bought some new valve springs and wanted to know if they would work fine on my car. I have the cam in sig and stuill the stock valve springs so im thinkning im getting some valve float in the upper RPM's what i bought was "Edelbrock Sure Seat"
they have a part # 5703... do these sound right for this cam. im not to knowledgable on this subject but i think that to high a seat pressure on a hydralic cam can cause lifters to collapse so thats is why i wanted to make sure. thanks in advance for the help.
Also would these work alright with my current stock rockers... i got some 1.6 aluminum rr's but i guess i need to get my heads machined for fitment.
Old Nov 3, 2004 | 12:31 PM
Damon's Avatar
You got the right ones. Just a little over 100 lbs seat pressure. They're just fine for any kind of mild performance flat tappet cam- hydraulic or mechanical. They are designed for a 1.70" installed height which is what most stock small block Chevy heads take (everything that came stock on 3rd gen Camaros uses that isntalled height, anyway).
NOTE: Your stock heads probably use exhaust valve rotator/retainers. If you continue to use them then just install the springs and put it all back together the same way. If you intend to swap out the exhaust rotator/retainers for standard retainers you will need to put a 1/16" shim under the exhaust valve springs to maintain the correct 1.70" installed height with the standard-type retainers.
Old Nov 3, 2004 | 02:20 PM
thanks very much just wanted to make sure it would work alright with me setup, from your guys experience do you think with the cam i got i am getting valve float with stock springs?
Old Nov 3, 2004 | 02:55 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Could be, how high or rpm are we talking here? But yes the stock springs now will be limper then..... You can fill in the blank. What cam is that, summit? It is a good idea to replace the stock springs when ever you swap cams even if your putting a stock cam back in.
Old Nov 3, 2004 | 08:12 PM
well about 5200 rpm since thats were the auto shifts no matter what anyways.
Old Nov 17, 2004 | 05:45 PM
IROC_385Z's Avatar
Car: 88 Camaro IROC-Z
Engine: SBC 385
Transmission: 700 w/ manual valvebody & 2400 TCI
Axle/Gears: 9-bolt B&W w/ 3.70s
What needs to be done with your heads, the studs?
Old Nov 17, 2004 | 06:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
5200 RPMs is exactly where my stock 305 springs floated.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
