removing AC clutch coil
Car: '87 Camaro LT
Engine: 355 L98
On an H6 Harrison compressor... I have the clutch disk and pulley off but not sure how to get the coil off. I think it's a press fit but there isn't enough room under the coil to hook a puller in. Tips?
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
it's pressed on, i'm not sure how that one is, they make a special puller for it, i just did the clutch/coil on my v5 compressor on my beretta, i'll never do that again.
Car: 1986 Camaro SC
Car: '87 Camaro LT
Engine: 355 L98
Is this the puller you used? This is the loaner from Autozone for compressor pullies, the teeth won't fit under the coil, though. Maybe I should just grind the teeth thinner lol.
Car: 1986 Camaro SC
yes thats what i used, what i had to do was break the coil surrounding a bit where the teeth go to get the teeth to fit
but i think they have one for more depth
but i think they have one for more depth Thread
rsrmoore
Aug 7, 2015 08:44 PM
