Destroking the 350
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by ljnowell
THEGENERAL has a 283 in his 66 Impala right now. A little beefed up (a big cam, dome pistons, etc) with the original Slip N Slide Powerglide.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by THEGENERAL
and according to these guys in this thread i should be able to rev well past 10,000 rpms then right...LMAO......
I gotta honestly say that normally I shrug **** off like this, but to listen to people act like this is no big deal is annoying as hell.
Some of you will argue for months about something as stupid as using synthetic oil and whether or not Ram air is real, but when it comes to ACTUAL engine data you act like it's meaningless.
Originally posted by AJ_92RS
No. If you know about piston speed (which obviously a lot of you don't) then you'd know that it could safely rev to 8,000 RPMs and the bottom end would hold up, within reason.
man just relax its only the internet not like someone is at your job looking you in your face calling
....there is more than one way to achieve a said goal ......both could work in theory and both brobably have but that doesnt make one absolutely the only way to acheive said goal now does it ?
no it doesnt there are many ways to get a small block chevy to rev to and beyond 8000 rpms reliably and there are plenty of guys out there that can do it without a problem with very little done to thier engines ....not much more than a good heads valvetrain and a properly installed bottem end and will not have a problem at 7500 rpms all day long .....
i personally enjoy the sound of a 350 with balanced internals and a nice sound valvetrain that will redline around 8500+ all day without a problem i just dont happen to like a destroked engine i think its pointless to do that to one ....it makes as much sense to me as takeing a 350 and installing sleeves small enough to make it a 305 ....
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Now that the 305 has been brought up again, If you had a (say L-69) 305, and then you built a 4in bore 305 and everything else was identical, I'm going to say the 4in bore 305 will be the HP winner due to the fact that it can use larger valves, and if the valve size was identical, it would still be better because if of the (lack of)shrouding. It also (IMO) has a better bore to stroke ratio. If EVERYTHING (cam valve springs compression) were the same it would still not be abig revver due to the stock cam, but I believe it woud still see it's HP peak higher than the stock L-69. Certainly, if you could also change the valvetrain, the 4in bore 305 would kill the L-69.
Any comments on that one?
Car: check
Engine: check
Transmission: check
RBob.
The point being made is that no matter what the stroke the valvetrain is the limiter in a SBC engine. Math computations will prove, as you have said, that a shorter stroke engine has the potential to achieve higher RPMS, but all of that is pointless without the proper valvetrain.
To make my point, without math, look at these situations. A DZ302, can rev till the moon, and run perfectly. Its the classic example of the short stroke - high revving engine. But what about the guy down the road from me with a SB400 who's redline is around 8K? It definately is not a short stroke engine, and it has no problem. Because of the proper valvetrain that he has. Same applies to my engine. When I run hard, I shift at 6800-7K. Thats a lot of RPMs. Definately higher than a lot of people here spin too, on a regular basis. It has nothing to do with my stroke, or bottom end. In fact, its all stock. The valvetrain was where I put all the cash when I built the engine.
There are lots of schools of thought, and as you have shown that you can prove your point with computed figures and scientific facts, I can also prove mine with real world examples. Who's right? Probably everyone.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Originally posted by RBob
A 4" bore 305 is a 350.
And yes most of us are correct!
This is hilarious.
Now that I've stated the fact, contrary to your comment about stroke having nothing to do with an engine's RPM limits, you're now trying to make it sound as if I said the valvetrain doesn't have any effect on it.
I never said anything more that what I typed. I also know the valvetrain comes into effect. I never said it didn't.
It doesn't matter. The whole reason I posted was to point out stroke does have an effect. I improperly used the words in the correct spots (which I apologize for) but it turns into more than what it needs to.
Typical miscommunication. Nothing more.
Let's let it die, please.
Whats hilarious is that you get all bent out of shape because people refuse to take your word as fact. Sorry. Thats just not how it works.
In the mathematical world stroke may make a big difference. In the real world, it doesnt matter. Any engine can be built to take any RPM. Thats just how it is. Maybe someone will come in here and lock this thread, so that you can quit arguing with the rest of the board.
And I never said a 400+ engine with 3.75"+ stroke couldn't be built to handle high RPM. NEVER SAID IT!!!
My point is, and has been, that it's CHEAPER to build a short stroke engine for high RPMs because of piston speed.
That's a fact.
Car: 1985 Z28
Engine: LG4 305 with a few modds
Hey guys, you sound like you know what your doin, so I got a question for ya.
I picked the 383 route and this is my setup
350 .030 4 bolt main With ARP bolts
Scat cast steel 9000 3.75" crank
5.7" Scat forged rods
KB hyper flat tops
Internaly balenced
Valve train will be a Solid roller setup with a Compcams 300AR magnum cam and Compcams 1.52 pro magnum roller rockers
Will I be able to rev to 7000 rpms??? or even 7500 max??
KB hyper flat tops
Internaly balenced
That's a fact.
That's a fact.
they would both need to have a solid valve train in order to reach those rpms..
machine work costs would be identical
it would cost exactly the same to build one as the other and the effect would be the same.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Has it been said that a 350, 383 0r 400 or 427 don't want to spin as high as a 327 because since they have a longer stroke they are generating more torque and leverage to make breaking a rod or crank easier?
There is also a lot of talk about "doing the math." I would love to see this equation. What would it be? Logarythmic, exponential, linear? It has got to be hairy. It would also seem that there would have to be a diferent equation for any minute change (octane, bolt torque, advance, etc,.). I have not gotten to finite mathmatics yet, give me another semester.
Has anyone mentioned that that 50 whatever chevy might go faster because of something other than the jornal length or diameter?
It was said in another post that we belive that a 350 and up can sustain high rpms (or whatever) just like we belive that ram air and other stuff was not real. In another post ram-air was proved incapable at driving speeds by mathmatics, and here someone is saying that they can prove 327 can ___ better by using mathmatics. They argue that it is wrong in the ram-air case but right in theirs.
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Wow this got out of hand quick. Anyway you look at it the 327 rocks the party. I pulled a 100,000 mile motor out of a '68 truck(2 bolt) put in 270 dur., .468 lift, stock vortecs,air gap,750 holley. And put it in a 87 S-10 Blazer. Like I said before, its a monster. 6500 Rpms with little effort. It ran a 13.3 on street tires and NO tuning. With some jetting, some timing adjustments, we are expecting mid to low 12's. Oh yeah, friday I'm picking up a NOS kit for it.
I always heard stories about 327's. All the old timers swear by them, now I know why.:rockon:
I always heard stories about 327's. All the old timers swear by them, now I know why.:rockon: Look away for a couple days and all hell breaks lose.
Im lost here, you confused me. Are you agreeing with the short stroke thing, or disagreeing?
None of that has anything to do at all with it being a 327. None of it. YOu foudn a decent motor in a junkyard, big deal. Nothing about the 327 makes it rev any better. My 350 does the exact same thing. Bring some proof in here that will contribute to the argument, not the 327 rocks cause all the old people say so.
Wow this got out of hand quick. Anyway you look at it the 327 rocks the party. I pulled a 100,000 mile motor out of a '68 truck(2 bolt) put in 270 dur., .468 lift, stock vortecs,air gap,750 holley. And put it in a 87 S-10 Blazer. Like I said before, its a monster. 6500 Rpms with little effort. It ran a 13.3 on street tires and NO tuning. With some jetting, some timing adjustments, we are expecting mid to low 12's. Oh yeah, friday I'm picking up a NOS kit for it. I always heard stories about 327's. All the old timers swear by them, now I know why.
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I always heard stories about 327's. All the old timers swear by them, now I know why.:rockon: Even if the strokers do beat em in a race.
It takes a bunch more cam for a stroker to make the equivalent power @6500 rpm as a 327.
Don't let anyone tell you that you were only imagining that you were having fun.
FormulasOnly
Sep 10, 2015 09:07 PM
