What timing should I set my RS 87 to?
Old May 28, 2001 | 10:22 PM
vadrad's Avatar
Hi guys I am having timing done on my 87 RS 2.8 and as far as I understand timing is done by degrees so what it the best (Most HP) setting that I should set my car to?
Old May 29, 2001 | 12:35 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Set it to stock and go from there.
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 29, 2001 | 12:44 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Someone told me to set the base timing at 12* advanced for better throttle response. Stock is 10* advanced i believe. Bear in mind this is base timing, which must be set with the computer advance disconnected.
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
perZ
Aug 15, 2015 01:17 PM
