oil pressure sender
Old Nov 4, 2004 | 08:57 PM
csi1286's Avatar
Car: 91 Camaro RS white w/ T-tops
Engine: original 305TBI 140,000mi
Transmission: automatic (although standard would be preffered)
where to get an oil pressure sensor
where get i get an oil pressure sender/sensor for a 91 RS maro?
Also is there a mech gauge that can just be put on the block: sensor gauge and all in one spot on the block without routing into to instrument panel or console? I know this sounds stupid because you would have to open the hood to know the pressure but it seems much easier
Old Nov 4, 2004 | 10:27 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
you can get a sending unit at any parts store for a max of like 20 bux... do i the right way and just replace the sending unit man... dont cob it up...its an easy fix...
Old Nov 5, 2004 | 08:39 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
From Auto Zones web site
Oil pressure switch
it would be more time comsuming to "rig" up another gauge for oil pressure than using the OEM replacment sending unit.the hardest part is that it's a little ocward to get too.
Old Nov 5, 2004 | 10:46 PM
csi1286's Avatar
that i now know how the hell do i get this thing off. and what size wrench/socket or whatever should it be? seems like about 1 3/16 unfortunately that cannot be purchased anywhere.
thanks all
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
