max front tire size on 1991 RS
Old Nov 5, 2004 | 07:49 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
First of all I searched but my search terms are too short, TGO requires at least 3 letters to search.
I want to know if I can fit 255/50-16 front tires on a 1991 RS with the Aero ground f/x without hitting the f/x with the rear of the front tires.
Old Nov 5, 2004 | 08:17 PM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
with the stock IROC-Z rim you should be fine. before i got my 18in IROC wheels i had the stock IROC wheel and i ran 245/55R16 and had plenty of room.
Old Nov 5, 2004 | 08:43 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes they will fit, lots of people run 255/50-16's so 15's will be fine.
Old Nov 5, 2004 | 10:34 PM
Engine: 4.0L
Yes, I should have mentioned I am running stock 1986 Z28 wheels (16") with 255/50-16's.
If many people are running this combo why am i having a problem? The rear of my tires are hitting the valance f/x on both sides when turning but more on the passenger side. I have not drove it as it is for fear of damaging the f/x.
The actual car isn't a '91 RS but a '86 SC with the '91 RS f/x recently installed.
Cam I adjust the caster to move the front wheels more forward slightly? I do believe 1/2" should do it.
Old Nov 5, 2004 | 10:35 PM
Engine: 4.0L
Who's running 15's?
Old Nov 5, 2004 | 10:36 PM
Engine: 4.0L
Are there different offsets with different year IROC wheels?
Old Nov 6, 2004 | 12:53 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Oops sorry, i am a moron, it said 16 and i read 15. I've been 1 behind all day. You could adjust the caster, what is it now? The tires should not be hitting if you have the camber and caster set for performance. Adjust your caster in the postive direction, top of the strut back and your camber negative, top towards motor. Normally maxxing out the caster and camber works pretty good, it should also help out your rubbing issues too.
Old Nov 6, 2004 | 07:08 PM
Engine: 4.0L
The top of the strut is already all the way rearward on the passenger side, almost all the way rearward on the drivers side. The dirvers side doesn't hit as bad as the passenger side.
Shouldn't the top of the strut need to move forward to move the wheel centerline forward? How much movement of the tire can I get by moving the top of the strut?
Old Nov 6, 2004 | 09:07 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
No you are increasing the angle of the strut and wheel. But really the tire shouldn't move much at all. You might have something tweaked or your springs are sagging or something on that side.
Old Nov 7, 2004 | 09:13 AM
Engine: 4.0L
Nope, nothing tweaked or bent. The car drove straight. I totally re-built the steering with the PST kit plus extra missing parts and replaced all rubber bushings with poly. The spings are brand new Moogs also, look at my fender height they havn't even really settled down yet.
I figured that the tire size alone is the reason why they hit the f/x. That's why I asked if any members '91-92 RS cars with 255/50-16's installed have a problem or not. Close up pictures would be appricated.
Old Nov 7, 2004 | 09:28 AM
Andy Fanshawe's Avatar
Car: 91 camaro rs
I run 245's on the front on my 91RS, with the earlier IROC wheels though (single groove down each spoke). They run really close to the GFX. About 1mm off! 255's may rub on mine.
Andy.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
knight72
Aug 10, 2015 09:32 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
