ok need some opinions please
Old May 29, 2001 | 05:59 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
1986 305 stock carb, mods in signature, car is poping out of the exhaust like backfiring not loud, then sometimes out of the carb, timing is okay and stuff, could the valve lash be too tight?
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old May 29, 2001 | 06:18 PM
mrgto's Avatar
Sounds like the carb needs work. Ususally when that happens the float is stuck.
Old May 29, 2001 | 06:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Are you trying to say that you just adjusted the valves and that made it start doing this, and you're not sure you got them set right?
Valves don't tighten themselves. If the motor just commenced this all by itself, it's probably something else.
ICON Motorsports
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
