code 43
Old May 29, 2001 | 09:35 PM
formula14's Avatar
code 43
i am getting a code 43. I believe this is a knock sensor code. I have a fairly new knock sensor in. Whats the problem.
Old May 29, 2001 | 10:44 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Code 43----Elec. Spark Timing.----Poor elec. connection, open or a short in the circuit; defective ESC module; defective knock sensor; defective ECM.
Don't *** -u-me that the knock sensor is good just cause you changed it recently. Actually a bad connection to the sensor could cause this code. The ESC is on or near the power brake booster. It reads the knock sensor and sends voltage (8-10 volts) to the ECM. If the ESC detects knock, it stops sending any voltage to the ECM. This causes the ECM to retard timing until the knock is gone. If the ESC is bad, then it won't send any voltage to the ECM at all, even if the knock sensor is good. This will cause the ECM to fully retard the EST and set a code 43. Then you get really bad performance and fuel economy. Plus possible engine damage.
All I can say is start with the cheapest solution first.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old May 29, 2001 | 10:48 PM
AJ_92RS's Avatar
Oh I forgot. If the knock sensor is not hooked up, or not grounding to the ESC module, then the signal to the ECM will remain high, even if knock does occur. The ECM won't know it and will not retard the timing. This is what could cause the engine failure. This will also set a code 43.
[This message has been edited by AJ_92RS (edited May 29, 2001).]
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
