CES light not coming on, can't pull bulb.
Old Nov 9, 2004 | 10:35 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
I've heard that if the CES light does not come on once the ignition is on the on position, it can be either a burnt out bulb, or a bad ECM.
Where would you put your money - a bad ecm after 16 years and 175000 miles, or just a burnt bulb.
I know the burnt bulb SHOULD be easy to check - but I can't remove it without at least 2 hours of work in this peticular gm application. Also, if it's any consideration, I've been losing speedometer function every now and then as well (and when that occurs, the TC unlocks.)
Old Nov 9, 2004 | 11:32 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Dead bulb is more likely. I take it the vehicle has a digital speedo? If so then its probably a fault with the VSS or some other part of the circuit since the ecm looses the pulses as well.
Old Nov 9, 2004 | 12:26 PM
GOY's Avatar
GOY
I thought the same thing, but it just doesn't add up that if I bash the top of the dash, that the speedo will all of a sudden come to life and it be a VSS failure.
Maybe if someone else has had asimilar experience, and it was indeed the VSS, I will definately go that route, but I would like to know before blowing $30....
Old Nov 9, 2004 | 01:54 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Is teh speedo mechanically driven or digital?
Old Nov 9, 2004 | 02:25 PM
GOY's Avatar
GOY
Electronic - VSS at the tailshaft extension.
Old Nov 10, 2004 | 06:56 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i can't recall on my '91 with electronic dash stuff, but the light is probably one of those "integrated" types that come with a socket that need to be replaced from the rear of the dash panel. not too hard, just a little time consuming, but would definitely go there first to check the bulb. just my .02.
KAM
Old Nov 10, 2004 | 08:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
See if a scan tool will connect to the ECM. If so then the ECM is most likely good.
RBob.
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
