plugs #3 and #6 keep fouling out after 50 miles
Old Nov 9, 2004 | 06:43 PM
350 TPI's Avatar
I have replaced the 2 plugs every weekend now.The car has a cold start problem like all ninth injector TPIs.There is a ton of carbon build up on the plugs when i take them out with oily threads.Whats causing this?Blowby,leaky injectors,or bad piston rings?The car smokes really bad on startup but clears after a few seconds.Besides this it runs great.Do you think i will need to rebuild the engine or what?I have new injectors to put in and i am going to have a buddy to program a chip to kill the ninth injector.ANY suggestions are very much appreciated.
Old Nov 9, 2004 | 10:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you looked at the valve guides and seals?
Old Nov 9, 2004 | 11:12 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Along those lines, does it give a slight light blue puff at start up after it's been sitting for a while?
Old Nov 10, 2004 | 04:59 AM
350 TPI's Avatar
Stekman,i wouldnt call it brief.Actually for the 5 seconds it smokes its quite alot.So the valve seals would cause these to foul?I thought since it was only for about 5 seconds everytime its started that it would just burn off.
Old Nov 10, 2004 | 10:08 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It does burn off but it will still leave a residue there and over a period of time that residue will contiune to accumulate till it causes a bigger problem.
Old Nov 10, 2004 | 11:07 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
im interested in whats going on here also. i have pretty much the same problem with a fresh rebuilt motor in my truck. after driving for a bit the #4 plug fouls out and the threads are covered in oil. except mine does not smoke what so ever.
mdtoren
Aug 23, 2015 12:52 PM
jbd1969
Aug 17, 2015 07:06 PM
GVMV
Aug 16, 2015 08:01 PM
mdtoren
Aug 16, 2015 05:45 PM
Zachattack0925
Aug 12, 2015 09:52 PM
