'85 350 vs '90 350
Old Nov 9, 2004 | 07:05 AM
hot91t/a's Avatar
Car: 1991 Trans Am
Engine: built 305 carbed
Transmission: built 700R4
'85 350 vs '90 350
ive seen in magizines and catalogs where some products are made for pre 86 or after 86 and my question is whats the difference????? if i can get a response, that would be great. thanks
Old Nov 9, 2004 | 07:27 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There are a few primary differences.. The biggest is the change to a one piece rear main seal (in 1986).. Post-'86 car engines also started coming with factory roller camshafts along with center-bolt valve covers that seal better then the old perimeter style covers.. Another difference is the center pairs of intake manifold bolts. They are at more of an upright angle on '87-up engines (this is why you see the options on intake manifolds). That sums up the major differences I think.
Old Nov 9, 2004 | 10:19 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Yup... thats about it... bolt holes are a MAJOR diference. Just ask someone who has had to clearance and older intake for newer style heads, or newer intake for older style heads like me!!!
Old Nov 9, 2004 | 10:26 AM
thirdgen88's Avatar
Car: 1995 Corvette
Ok, maybe I should have said that one of the major improvements was the one-piece RMS.
Old Nov 9, 2004 | 10:28 AM
hot91t/a's Avatar
Car: 1991 Trans Am
so just the intake and the valve covers are the only thing that really matters. because im changing my 91 TPI to a carberated engine and im going to run no emssions.
Old Nov 9, 2004 | 11:04 AM
ljnowell's Avatar
If you are switching to a 2pc RMS you will need the flexplate from the older engine too. Be careful with this though, to make sure it has the same tooth count (ie. size) as your original, otherwise your starter wont work.
Old Nov 10, 2004 | 07:02 AM
hot91t/a's Avatar
Car: 1991 Trans Am
why do i need a 2 peice RMS or a one peice? or more like whats the difference
Old Nov 10, 2004 | 07:42 AM
thirdgen88's Avatar
Car: 1995 Corvette
If you are just changing your intake, you don't need to worry about it... The difference is the seal at the rear of the crankshaft, the one-piece is the newer design and requires the use of appropriate flexplate/flywheels.
Old Nov 10, 2004 | 08:52 AM
hot91t/a's Avatar
Car: 1991 Trans Am
well im rebuilding the whole engine whats your suggestion
Old Nov 10, 2004 | 01:35 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
That would be to order the correct kit for whatever engine you plan on rebuilding so you get the correct VC gaskets and RMS. Also the newer engine kit will come with intake gaskets with restrictor holes for the rear coolant passages you wont be needing those kinda of POS gaskets.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
