Motor Knocks When I Punch it
Old May 25, 2001 | 11:38 PM
MadBrewer's Avatar
(Same sound like when I try to start off in 3rd when I think I'm in 1st),...
As long as I'm not really heavy on the pedal, sounds fine,....just when I really hit it.
Buddy of mine thinks it's the bearings rattlin' & if so, how much more time til I have to really worry about it?
It's my daily drive & I put 100 miles a day to & from work
('91 Formula, 305 TPI, 95k)
<A HREF="http://www.geocities.com/d_madbrewer/moonshiner.html" TARGET=_blank>
Got Home Brew?</A>,....
If you can catch a quick race @ 5am on your way to work,....win or lose, it'll be a GREAT DAY, (better than coffee)
Old May 26, 2001 | 10:30 PM
Vader's Avatar
MB,
A few questions first:
What is the oil level and pressure?
What oil are you using?
Are you allowing a full warm-up before loading the engine heavily (full throttle)?
Does the noise vary with engine RPM or road speed (which one, or both)?
Do you have an engine crane?
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 30, 2001 | 07:05 PM
MadBrewer's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Vader:
MB,
</font>
Thanks Vadar;
Between add & full, (1/2 qt., 1-2 a week);
Been lazy w/Chevron;
Takes 5 min to get to on-ramp;
Neither, happens on a quick jump, (like idle-to-half throttle or, a cruise-to-3/4 throttle);
"engine crane"?
Thanks again,
Wounded Knee
BTW; if you see a black, clear-coat-peelin', Formula between Merced & Modesto & I'm NOT runnin' w/you, hopfully soon
[This message has been edited by MadBrewer (edited May 30, 2001).]
Old May 30, 2001 | 07:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
MB,
</font>
lololol He may need that!!!!
Old May 30, 2001 | 07:19 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
<font face="Verdana, Arial" size="2">sounds like you're taking off in 3rd when you think you're in first...</font>
i think you're engine is pinging... check the timing with the EST disconnected, it should be about 6 degrees BTDC if your motor is essentially stock..
Webmaster: www.IROC-Z.org
[This message has been edited by ColinOpseth (edited May 30, 2001).]
Old May 30, 2001 | 07:26 PM
MadBrewer's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mkos1980:
lololol He may need that!!!!</font>
I think I just walked into something,..........
Old May 30, 2001 | 07:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Engine crane is a crane to pull the old engine out to replace it with a brand new one. We are saying maybe your engine is shot and you need a new one. Probebly not though.
Old May 30, 2001 | 07:38 PM
MadBrewer's Avatar
Cherry Picker,......
I knew I was slow on something,
perhaps I need another brew
italiano67
Dec 11, 2016 09:21 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
db057
Aug 22, 2015 08:17 PM
st.evel07
Aug 13, 2015 06:15 PM
gwade12
Aug 8, 2015 08:17 AM
