Top Dead Center
Old May 30, 2001 | 01:51 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Top Dead Center
OK getting ready to drop the Dist. in and set the timing. The balancer is on 0 and the #1 cyl has both valves closed #6 cyl. has bothe valves closed. Is this top dead center for the intake???
Brian
1989 Camaro RS
305 .030 over
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter Ultimate TBI mods...14X3 K&N open Element Non-Drop... LETS PLAY FORD!!
Old May 30, 2001 | 02:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
#6 exhaust should be closing and #6 intake should be just opening. #1 intake valve should have closed almost ½ of a crank revolution earlier.
ICON Motorsports
Old May 30, 2001 | 03:02 PM
SO am I right to drop the dist. in or am I 180* off.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
Old May 30, 2001 | 05:46 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
nm.. the other dude is correct
[This message has been edited by ColinOpseth (edited May 30, 2001).]
Old May 30, 2001 | 07:04 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
Keep turning the engine over until you feal air pushing out of the #1 cylinder then bring it to top dead center. then you are at the #1 firing position.
Old May 30, 2001 | 09:12 PM
OK I See but with both valves closed it would have to have air pushing out correct. I have no Idea but I will take any info you guys can give.
Brian
1989 Camaro RS
Old May 30, 2001 | 09:14 PM
Engine: 305TPI
it would push air, yes, because the piston is rising on the compression stroke..
you know the 4 strokes, intake, compression, combustion, exhaust..
on compression stroke for that #1 cylinder the valves are closed, the exhaust will begin to open as soon as the piston begins downtravel in the cylinder
Old May 30, 2001 | 09:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You could still drop the distributor in but remember that it's on TDC of #6 so the rotor needs to point to #6 plug wire.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
1992 Trans Am
May 10, 2023 07:19 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
g.l.mos
Aug 22, 2015 12:02 AM
