My new setup.
Old Nov 10, 2004 | 06:27 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My new setup.
Working on my new setup. Heres the build so far. Some of the parts came off the old setup.
Trickflow 23* aluminum heads, 64cc chambers
SRP Forged 383 blower pistons, -16cc dish
Scat 4340 H-beam rods, 5.850" long
GM Forged steel 3.480" stroke crank, 1 pc rear main
Felpro .039" lock-wire head gasket
Deck milled for piston .005 in hole, for .0044 quench area
9.14:1 compression ratio
hydraulic roller camshaft.
Cat stainless full roller rockers
Holley dominator single-plane manifold, converted to EFI
Vortec 80mm throttle body
Vortech S-trim supercharger, 3.33 pully, max boost. (around 12)
50lbs injectors
I'm thinking if my old setup was trapping 119mph in the 1/4, this new setup HAS to be good for at least 128-130mph. I'm thinking (flame me if you wish) this setup should be upwards of 560-580hp. You decide.
I'm considering these two camshafts. Basicly the cam is the only thing I dont have yet:
CC-303-8 236/248 .520/.540 113lsa
CC-306-8 230/244 .510/.540 112lsa
-- Joe
Old Nov 11, 2004 | 09:01 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
A simulation of each cams powerband:
plm99
Southern California Area
Nov 16, 2015 05:21 PM
tattmann
Sep 27, 2015 05:20 PM
Liveaction
Sep 17, 2015 06:29 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
Doobie52
Sep 11, 2015 06:19 PM
