Oil Pump? HV & HP or just HV
Old May 30, 2001 | 07:24 PM
GlenYappa's Avatar
I am building a mildly SCed 350 for my 84 Camaro. 8 to 1 compression with a street blower which should be emmissions legal. I can get a high volume and high pressure oil pump or just high volume or stock. I was thinking high volume but not high pressure would be good. When do you need high pressure and/or high volume?
Thanks,
Glen
Old May 30, 2001 | 07:25 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
i put one in my '87 IROC when i did the motor...
way too much pressure imo, i believe it was the P55-HV or something... it was by Clevite, what a piece of crap.. i ended up pulling my oil pan off and putting in a stock Melling..
Old May 30, 2001 | 07:29 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I like mine regular. Search the old threads and archives, you will find this issue hashed about about a lot.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old May 31, 2001 | 05:53 AM
GlenYappa's Avatar
I searched the archives and got a lot of info. It seems most people prefer a stock pump. I have a high volume pump but I think I will be OK since I have a 6 quart oil pan and a high volume pickup to match.
Old May 31, 2001 | 06:11 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
there are two HV designs. The original HV was just a bigblock (five bolts on the cover) pump. If your not carefull, you will run a stock pan dry with this pump. You need to ensure oil drain back and that the pan has sufficent volume. The latest ones are still 4 bolt covers but they have enlarged pickup tubes. These don't take the extra hp like the bigblocks pumps but you still have some of the same issues. I would not use an HV without an aftermarket oil pan.
Old May 31, 2001 | 09:05 AM
FastBroker's Avatar
For blower motors, I run the "hv" big block pumps, a bigger pan and Mobil-1 10-30 or 10-40, depending on the setup. Conventional oil with these pumps usually allows too much oil pressure at cold startup...
Old May 31, 2001 | 09:20 PM
ede's Avatar
ede
i like the melling m55 with a mr gasket #26 spring. i weld a brace on the pick up and bolt it to the pump body. i've done a lot of SBC and a few v6s this way and never had an oil pump related problem. rpm's never went above 7000 on any engine far as i know.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
