hei help needed
Old Nov 14, 2004 | 02:21 PM
bland_cd's Avatar
Car: 89 camaro iroc
Engine: 5.7
Transmission: 700
hei help needed
all new ac/delco ignition parts, with by-pass wire off and base
timing set to 6 degrees as per the emisson sticker, car runs
smooth, put wire back on and clear fault, the thing starts
missing badly and timing goes way advanced, I am new
to these ecm controled ignitions. Anyone have any idea what
could be causing this?
Old Nov 14, 2004 | 05:26 PM
Vader's Avatar
Once the ESC is reconnected, the timing will generally advance anywhere between 10-20°. That's rather common. What isn't common is that the advance would cause misfire. If the knock sensor were faulty, the ESC may react by varying the advance wildly. It is also possible that the ESC has a connection problem or internal problem that is loading the HEI module and causing weak/undefined spark references.
Old Nov 14, 2004 | 05:33 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
the 5v refrence you dicoineded is conected to a coil. and electricy flows though it it creats a megnetic feild... pull 2 swiches down to a diffren't pos. letting the comp controll the advance you knock sesnosr will be bad if it keeps advancing and advancing then will start to knock and not know try that
Old Nov 14, 2004 | 05:47 PM
bland_cd's Avatar
Car: 89 camaro iroc
Engine: 5.7
Transmission: 700
the book says that I should be getting 7 to 9 volts steady out of
ESC until it senses a knock, then the ESC will take away the 9 volts to the ECM. I have a steady 9 volts all the time and here no knock. don't know if I am getting the 9 volts to the ECM, I'll
check that, any more ideas while I am out there. Its my boys
car, he got it right now, drives ok with that wire diconnected,
no Zip, but it gets him around till we figure this out. THanks for the help
IROCZ1989
Jan 24, 2016 03:55 PM
midias
Aug 15, 2015 05:07 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
